D4 6U Low Fuel Pressure
3 years 1 month ago #230605
by Keltonc87
So I have a issue with low fuel pressure currently. The dozer was in a fire and just got hot on the left side where the fuel filters are. Before the fire the fuel pressure used to peg the gauge, I’ve changed the fuel filters, rebuilt the transfer pump and check tolerances, replaced pressure return spring and plunger. With the pony motor cranking it over it’s got about 5psi and won’t start. I know the pump is getting fuel but it’s bleeding off somewhere. I was wondering if it’s leaking between the filter housing and the infection pump, I can crack the fuel lines and fuel comes out but not a lot of pressure. The dozer did start once but fuel pressure was about 10psi. Then tried to start it 6-8 months later and nothing
Thank you received: 409
3 years 1 month ago #230606
Check how well the relief valve in the transfer pump is sealing - it might have melted a bit
3 years 1 month ago #230608
Are you getting fuel in the main engine sump? That would indicate the tower to injection pump seal is leaking.
3 years 1 month ago #230609
by Keltonc87
It should be sealing perfect, I replaced the relief valve and spring and also machined the surface as well.
3 years 1 month ago #230611
by Keltonc87
Yes, with the main engine cranking it has about 5psi and I can crack the bleeder on the top of fuel tower and fuel comes out but now under a lot of pressure. Also the injector lines have fuel coming out but not at much pressure
Thank you received: 387
3 years 1 month ago - 3 years 1 month ago #230621
bad injection pump seals. put a full seal kit through the injector pump they can just fail.and since it got burnt it may have ruined the seals.
did you check the relief valve seat a new valve with a poor seat wont fix any thing
Thank you received: 341
3 years 1 month ago #230638
by edb
if you have low pressure fuel issuing from the injection pumps then the rack is in the closed position. The operators lever sometimes needs a good tug backwards to get past the shutoff detent inside the Governor which could be likely due to the heat gumming up the oil in the pump and governor housings.
Failing this then you have either a stuck rack or stuck injection pump plunger NOTE resist the urge to rotate the inj. pump plunger by forcing the rack as it is possible to rotate the gear quadrant on the inj. pump plunger and loose the factory test bench set fuel delivery setting rendering the stuck pump useless without a proper test bench to re-set said pump up on.
Spray the inj. pump plungers with your favorite loose juice and gently pry the stuck inj. pump lifter up and down by its yoke--some very gentle tapping up and down may assist--stuff in the side cover of the injection pump is very hard steel and so is fragile.
If your Inj.pumps have the bleed screw pictured in the scans these need to be bled too for easier fuel bleeding to thee injectors--later Inj. pumps do not have the bleed screw and are self bleeding due to changes to the hollow dowel that sends fuel to the Inj. pump body.
The Inj Pump seals will appear triangular in shape when removed as this is the shape they attain after years of being crushed in situ--the replacements are round O Rings as were the old ones when originally fitted--same for the Inj. pump main body fuel gallery dowel O Ring at the fuel tower.
Let us know what you find and we can assist further.
3 years 1 month ago #230697
by Vance Nickerson
When my D47U sits a while the pump plungers stick and definitely give the linkage a good tug as I missed a show from that simple thing last year.
3 years 4 weeks ago #230847
by Keltonc87
Thanks for all the info, I’ve bled out all that air that I know of, I’ve cracked the lines at the injectors and fuel comes out pretty steady. According to the pressure gauge I’ve got about 4psi at the filter housing. I was wondering if the seal could be bad between filter housing and injection pump and if it’s bleeding fuel into the crankcase.
