D17000 connection
D17000 connection
Thank you received: 50
3 years 1 month ago - 3 years 1 month ago #230548
by hfdzl
Would anyone have information on a D17000 generator part #6F1956, serial # 6805674 ? How is the DC exciter connected? Will the generator make power just as it is? I found 5 non Cat wires connected to a switch with capacitor that was operated by the throttle control. What does that do? It was not connected to the generator. The genset is connected low voltage with neutral. 120/240 v
Thanks, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Last edit: 3 years 1 month ago by
hfdzl.
3 years 1 month ago - 3 years 1 month ago #230552
by hfdzl
Beating my head many times against hard surfaces, I found the information I needed. The box is a Modutrol control. This is a motor that controls the governor on the generator from a remote location, ie service panel. I remember them from way back for boiler controls, probably obsolete with the electronics updates now. Sometimes I just have to let the internal computer settle down and spin around for a while!
I still would need the connection for the DC exciter.
Thanks for looking, Herb.
hfdzl.
Thank you received: 341
3 years 1 month ago #230579
by edb
Hi Herb,
sorry mate but it helps immensely if you keep all posts relating to a particular machine in one thread as I had to trawl back some 5 pages to see a picture of your unit to check which Generator Set unit you had.
Hope the scans help some.
Regards,
Eddie B..
3 years 1 month ago #230582
It would appear that your generator was set up for remote manual voltage control.
Here is the wiring diagram.
3 years 1 month ago #230583
by hfdzl
Thank you for this valuable info.! Now I can get this sorted properly.
Thanks, Herb
3 years 1 month ago #230590
by hfdzl
So to have this unit be self regulating , the original Caterpillar throttle linkage would have to be replaced? Or would have to be manually adjusted for output?
Thanks, Herb
3 years 1 month ago #230591
The engine throttle control would still be used to set up the engine running on governor control then switched to automatic (self) regulation. Final voltage will still be controlled/set by the remote Exciter Rheostat.l
3 years 1 month ago #230592
by hfdzl
This setup probably never be used as standby power use. I would like to take it shows, having to be able to run with a few light bulbs to show that it does make power. The less hardware, switches, cabinets etc would be better. A main switch that controls the load is all I need.
Thanks, Herb
3 years 1 month ago #230596
You haven't talked about starting...but be aware that the electric pony starter for the D17000 has a position switch on - off and in between. In the in between position, switch vertical, the starter motor will rotate at a slow speed to allow engagement of the pinion. Caution warning about engaging pinion at full speed.
3 years 1 month ago #230604
by edb
just to add some more scans that may be of interest.
hfdzl
D17000 connection
