Valve guide part number question
Thank you received: 6
3 years 1 month ago #230463
by Catboy1
I have recently come across some valve guides, part number 4F6949 A. My parts books say they will fit on the D315 and early model D318's. My D6 9U is in the 27### range. Will they work on that engine? Thank you,
Robyn
3 years 1 month ago #230471
by Catboy1
Thank you. Do you happen to know the difference? It looks like all head assemblies are the same part number, and the valves as well.
Thank you received: 94
3 years 1 month ago #230472
by josh
I see several heads that can use either the 4F6949 or 4H0621, used on 9U1- 29764 and 7U1-44307 and others.
3 years 1 month ago #230473
They are different, maybe not by a lot...
4F6949 length = 4.188" vs 4.250" for the 4H0621
4F6949 OD = 1.062" vs 1.562" for the 4H0621
4F6949 ID = 0.4375" vs 0.4400 for the 4H0621
Other shape dimensions are also different.
All my literature shows distinct different valve guides across the s/n's.
3 years 1 month ago #230475
by josh
The 4F6949 and 4H0621 guides are quite a bit different, but they are both used in the same head assemblies, and with the same valves and springs in both. Looks like the 4H0621 is a one piece guide, but the 4F6949 also requires an additional part, spacer 5F3110 if you were going to replace the 4H0621 with 4f6949.
3 years 1 month ago #230494
by Catboy1
Thank you very much. Old Magnet, what books do you have that give you the measurements of the parts?
Thank you received: 118
3 years 1 month ago #230495
by Ray54
The heads on a 318 are as tuff as any you will find, but it still may have been changed in 60 years. So the head may be the earlier type, so check before looking for other guides.
3 years 1 month ago #230501
by Catboy1
What do you mean by the earlier type? My parts book is from 9U13263 up, all of the heads are the same number in there. Was there a different style before those serial numbers?
3 years 1 month ago - 3 years 1 month ago #230502
The OD makes quite a difference in the press fit.
The ID is significant when selecting the valve seat grinding pilot.
Early heads, part number 5F1305, casting #3F9903 were used to s/n 9U11704
Late heads, part number 1H7659, casting #7F7878 were used 9U11705 up and have the larger diameter pre-com chambers to accept glow plugs.
Time to create page: 0.165 seconds
