Tips on freeing up stuck D7 3T?
Thank you received: 16
3 years 1 month ago #230428
by Mangoman
Hi folks,
I have a good friend that has recently purchased a D7 3T. Or at least I'm quite sure it is a 3T but we haven't found either of the plates yet. I'm a little foreign to these larger tractors, having only owner a 7U and 5T. This machine looks to be well kept but has sat for about 15yrs. The pony gave us only minor inconvenience in getting it fired up and running decent. Now the diesel on the other hand is stuck as far as we can tell. With the pony running at rated rpm (no hand throttle on a vertical pony?), when the clutch is pulled in, it just stalls the pony instantly. Doesn't even budge the fan blades. High or low gear it doesn't matter. My friend has poured diesel/ATF down the stack and it has been sitting a couple weeks. Any better ideas or should we go for the jugular and just lift the heads? It holds water as far as we can tell. Oil level is maintained where it should be. Both stacks were covered but maybe condensation has stuck the rings?
Much thanks everyone
Thank you received: 387
3 years 1 month ago - 3 years 1 month ago #230430
remove the exhuast manifold, rocker covers and air intake pipe. see if the valves are stuck if you can move em good get a large bore syringe and put a a couple of syringe fulls of diesel and oil mix down each cyl via the valve port.
wait a few days then gently rock the crank back and forwards. if you can pull the side cover give the journals a good squirt of lanolin spray too. oil thinned with diesel or kero would work too its just to lube things so your less likley to do damage.
if that dont work then yes it pull the heads add diesel and a block of wood and give each piston a few love taps and leave it for a day or 2. it takes a week or so top up the diesel each time.
Thank you received: 142
3 years 1 month ago #230432
by bursitis
lanolin spray? i have a product called fluid film that is high in lanolin. is this what you are talking about?
Thank you received: 409
3 years 1 month ago #230435
Also disengage your main clutch in case the input shaft in the transmission is seized and check if the shaft turns over. That's caught out some before.
3 years 1 month ago #230465
by Mangoman
Thank you everyone. All great pointers. I use fluid film on my truck in the fall before the nasty salt sand of the winter. Never really thought to use it in more of a penetrating oil application but perhaps it works well? Neil, I will certainly get him to disengage the clutch as well.
Does anyone know the best way to manually turn these motors? My friend is getting all panicky over the thought of having to possibly pull the heads. I dunno. Can't be that bad on one or these dinosaurs. Perhaps could rig up a hoist off the sweeps? I'm any case I think it is well worth the work.
Thank you received: 341
3 years 1 month ago #230474
by edb
suggest you first check you have no seized valves on the main engine--if none are found,then there should be a 4 bolt rectangular cover plate on the top of the main engine flywheel housing that has the timing pointer in under it.
Remove said cover and then the pointer and you should be able to judiciously pry on the ring gear teeth--try moving the flywheel back and forth to see if you can get any movement.
Report back your findings and we can go from there--could be the water pump is stuck too.
Mangoman
Thank you received: 6
3 years 1 month ago #230478
by Andrew
If you put the starting engine gear box in low. engage starting pinion and clutch and turn starting engine crank by hand . this will put a large force on the crank .
Also I have freed many by pressurising the stuck cylinder with hydraulic oil.
3 years 1 month ago #230483
by Mangoman
Thank you Andrew, Ed B.
Ed B, so the idea is remove the valve cover and rubber mallet on the top of the valves or pry bar the rocker? I will certainly make sure we check this out. If the water pup is stuck, perhaps we will get the crank to nudge but see the pump is completely stationary I suppose? I guess in that case it would mean pulling the pump and separately trying to free it?
Andrew, how did you pressurize the cylinder? I guess that would be for a cylinder with closed valves.
Gracias amigos
3 years 1 month ago #230484
pretty much but fluid film is more of a heavy duty coating for protecting metal and timber parts during storage etc. the product i use most is called lanox and is more of a penertrating lube
there is several brands and some have different strength formulas for different jobs. with any of these sprays shake well before use as they do settle out.
3 years 1 month ago #230485
i have heard of engines with stuck pistons freed using grease they made a cover plate to bolt over the cyl with a grease nipple in the middle and pumped it full of grease the standard grease gun will develop 10,000 psi.
Time to create page: 0.194 seconds
