1955 14 A Clutch Help
3 years 1 month ago #230299
by mcarey65
I need a need a clutch disk for my 14A D-8 or have the one that was in the machine built up. The adjustment was all the way in and still slipping badly. Any information anyone can provide on where to purchase one or if and how they can be built up. We have it out of the machine just not sure what type of material they use on these. It is similar to break lining. .
Thank you received: 409
3 years 1 month ago #230300
If it's like my 5U clutch disk, you get the lining material that the clutch shop uses these days. Your local brake and clutch shop should be able to take care of it for you. They glue them these days so don't be surprised if you don't see rivets in it.
Thank you received: 39
3 years 1 month ago #230305
by gemdozer
The 14a master cluch have 3 discs and 2 plate and should't be rebuiltable make sure the plate are't to worn too and am still have 2 discs and the tickness are approximatif .295 .
3 years 1 month ago #230326
by mcarey65
Thank you Neil, my dozer is actually a 15A with a torque converter. It has a single disc clutch. I am wondering it the thickness would be the same as the clutch plates for the 14 A?
3 years 1 month ago #230336
Probably - everytime I take a plate in to be relined, they just put on "standard" linings and it always works out. I want to say 1/4 or 3/16 seems to be standard. If 1/4 for example is twice the current thickness of your plate, then it's probably close enough. Someone that's actually swapped one out might have some more intel for you, but that's the direction I'd take if no more useful information was forthcoming
3 years 1 month ago #230429
by greghill25
New reproduction disc assemblies are available at www.steeringclutch.com
That looks like a nice place to get new clutch discs. My uncle is looking to rebuild this D8 14-A and it might new some major parts including the clutch. We'll just finish installing the bumper and
truck shocks
on the Silverado this week before we take a closer look at the D8.
Time to create page: 0.158 seconds
