Pony motor
Pony motor
Thank you received: 409
3 years 1 month ago #230271
Hi Pyo, I don't have a picture but if you look on top of the clutch housing, you should find a cover that you can remove to gain access to the pinion end. On the D2, there is both the main clutch cover and also a small round cover about 2" diameter. You may have something similar on the D6. If you have the small round cover, you can poke a screwdriver in there, push on the end of the latch lever to disengage it. I'll see if I can find a picture but someone might already have one they can post
3 years 1 month ago #230276
Is it starving of fuel? I had an old batch of gas put in my 5U's pony and it ran like a bucket of bolts - had to have the choke on to get it to run enough to start the main. Will be swapping out without delay : )
Thank you received: 7
3 years 1 month ago #230278
by ChrisRoyd2
Could be restricted flow between the tank and carburetor. As you wind the rope it has time to fill bowl then when it starts it can't get enough fuel to run longer. Does it start relatively soon after it quits?
3 years 1 month ago #230289
Does it behave the same way if you a) turn on the fuel and let the bowl fill, then b) turn off the fuel and start it. Does it also run for 30s on just a bowl full of gas (or 10s or something). If so, there could be detritus somewhere between the fuel tank and the bowl. One of the members here had a tractor that would often conk out at random periods. It would start right up again and then run for some other random length of time. Turned out to be a foreign object in the tank that he couldn't see that would occasionally block the outlet. After changing easy things like the plugs, the wires, the condensor and points, and cleaning the fuel bowl, I'd start at the tank and positively confirm everything downstream is clean and clear. By positive I mean run flow tests, not just a "look" for an extended period of time. For example, fill the tank with fuel, and confirm that it will run through the tank, the pipes, the carb fuel bowl without degradation until the tank is empty. At some point, you have to work methodically and thoroughly to isolate the problem.
Thank you received: 191
3 years 1 month ago #230290
by D4Jim
Might not be a carb problem. Could be a fuel problem getting to the carb so may be a partially clogged fuel line or screen.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
3 years 1 month ago #230292
by Pyobluebonus
I filled the tank and let it run out drains tank perfectly. I will pull carburetor again. 3 time a charm.
Thank you received: 387
3 years 1 month ago #230295
as neil has said another member found a sales reciept is his fuel tank what amazed him was it was still legible.
the other issue could be spark failure when the mag coil get a bit of heat in it. that why its important for them to be hot tested. a bad rewinding job especially if they didnt impregnate the coil properly with the special varnish it can fail. just becuase it was rebuilt 5yrs ago doesnt mean its still good today age and moisture deteriates the varnish especialy if it wasnt done properly to begin with.
Pony motor
