- Thank you received: 387
I can't say about Toyota's reasoning for a slant engine but Chrysler's was to reduce the engine height thus allowing lower hooded cars. Had nothing to do with wear. Also Ford had a diesel slant engine in some of their trucks that also had nothing to do with wear just the lack of room to get one in the engine bay.not only should they be staggered they should not be on the wiped side of the piston ie when looking at the crank pulley if the crank rotates to the right the right side is the wiped side. in other words the ring gaps should not be on the loaded side. all reciprocating engines have a loaded side and they wear that side more hence why bores wear oval.
Chrysler and Toyota famously tried to counteract this by building slant engines.
as for gaskets needing sealants or not some engines do and actually acl bearing co recommend the use of hylomar gasket dressing on their gaskets. unless you have had the mating faces ground a dressing is reconmended and unless the surfaces are out of true i wouldn't get them ground. there is several gasket dressings on the market be sure to select the correct one for the application as there is different products for different jobs.
as for a cyl hone ball type hones cut faster flat stone type cut slower but less likley to over cut. both types should be lubed with a mix of kerosene and oil or diesel fuel. keep the surface wet while honing a (spray bottle works best) then scrub the bores with hot soapy water or water based degreaser to remove all the grinding fines wipe dry and oil with wd spray or lanolin spray immediately to stop rust.
AND NEVER REUSE A GASKET that is asking for trouble. the only exception your in the bush hours away from home and have no other choice but then when home you replace it.. do it properly the first time and you dont have to touch it for years especially if you dont use it much. dont skimp on oil changes bad maintenance is what causes most failures.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
