D17000
D17000
Thank you received: 50
3 years 2 months ago #229656
by hfdzl
OK now it becomes plain. There is another member that is in Hancock, I cant think of his handle right now I'm north of Springfield.
I get the pronunciation!.
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 46
3 years 2 months ago #229662
by dpendzic
Only the locals from BROOKLYN !!!
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Thank you received: 39
Thank you received: 409
3 years 2 months ago #229738
There's a great video of someone starting a D379 (they called it a D397 - I don't know if that's a spelling mistake or is a different engine - in any case the one on the web is a V12) using a D2 and belt pulley to a flat belt pulley on the crank of the D379. That's some pony motor : ) and it makes it work too when they enable compression
3 years 2 months ago #229750
by gemdozer
The motor block parts number is 6l2533 and it is v8 cylinders and he should be in contener for CHINA soon last saterday metal price $335.00 tons
3 years 2 months ago #229768
by hfdzl
Got the deal done and a handshake! They will load , I am OK there. Gen serial #, 2754 no other id such as 8S etc. Gen part # 6F1956. Serial # 6805674. Pony and main stuck. I have no further info . Maybe someone can investigate those gen numbers. Will have more photos when I get it home and safe.from the general population!
Thanks, Herb
3 years 2 months ago #229944
by hfdzl
I have a couple projects ahead, I really want to get this big boy running too!!
3 years 2 months ago #229984
And then get it on the dyno Herb!
3 years 1 month ago - 3 years 1 month ago #230016
by hfdzl
Thanks, Herb
I did get a close look at the sn. Not 2754 but 2V54. Common mistake.
AND did get the big engine to turn! Not far about 3-4 in on the flywheel, so I think that may be OK. Pony motor is still a lump.
Last edit: 3 years 1 month ago by
hfdzl.
D17000
