- Thank you received: 0
Thanks Josh, I had not appreciated that. The parts books in the library are for 922 Traxcavators serial numbers 59A1-UP, 63A1-UP and 94A1-3929.Just for information, the 922 Traxcavator is a wheel type machine.
I can't be 100% sure on the 922 but the 944's serial is on the right hand side of the machine on the main frame just under the main lift arm pivot pin and the engine serial number is on the oil cooler side of the engine near the fill point. If the engine is original then both serials should be the same.Can someone give me an idea where to look for the serial #, Thanks again
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
