clutch
clutch
3 years 4 months ago #228536
by mhar
I have a d2 and the clutch either slips so the dozer doesn't move or it can spin the tracks How do I fix this?
Thank you received: 43
3 years 4 months ago #228537
by ag-mike
Main clutch adjustment should be covered in operators manual.
mhar
3 years 4 months ago #228615
by mhar
I went through the Jen sale book and found it on the internet how to ajust the clutch but the tractor is having problems disingauging what next?
Thank you received: 409
3 years 4 months ago #228619
By "problems disengaging", do you mean it won't disengage at all, or will disengage with some difficulty? If the latter, what sort of difficulty? There's not a lot of difference between under and over adjusted - typically only one or two holes. If you went say 8 holes, then you overshot. Adjust it halfway back to where you were originally and see what you get. Also, if the adjustment is not the problem, then your pilot bearing could be seized.
clutch
Time to create page: 0.137 seconds
