Old Magnet, Steering Clutch Discs
W.K.TEDDYBEAR
Visitor
User
17 years 8 months ago #2188
by W.K.TEDDYBEAR
the KING got luckly today, big time, LOL. so i worked my magic with the torch and it popped off with a couple of taps.
THAT MUST HAVE BEEN SOME GOOD MAGIC,WHERE CAN I GET SOME OF IT?
GOOD JOB!
TAKE CARE AND HAVE A GOOD ONE1
PAUL
17 years 8 months ago #2208
KoO,
Did you find anything more on the track truck alignment. If the sprockets rims are not weld on (misaligned) and there is room for adjustment on the inner pivot of the track frame and you've done all you can with the shims then it's time to check the stuff the manual doesn't tell you like how far up the splines the sprocket hub is pressed and the location of the pressed in dead axle. Not good news but now is the time to check with the tracks off.
17 years 8 months ago #2323
by Dirt Dog
the KING got luckly today, big time, LOL. i was changing the seals on where the shaft goes through the crown gear and found a toasted bearing. of cousre it is the hard one that you can't see behind the crown gear. so i worked my magic with the torch and it popped off with a couple of taps.(remember i can only see about 1/4 of an inch of this bearing) i was so lucky that the torch never even came close to the shaft. then i used my GREAT WHITE NORTH power pack and pressed on a new old stock bearing on.
it was a good day in the KINGDOM and only -35C.
thansk
Hey King, I see how you pressed the coupler back on the tapered shaft, but what kinda equipment (rig
) did u use to get the coupler off.
1958 D6 9U 27839 ~ 1944 JD BO Lindeman Crawler SN 333969
My favorite 2 toys are pullin' tractors and pushin' tractors.
My pullin' site
17 years 8 months ago #2332
by King of Obsolete
dirt dog, i used the torch and nicked the crap out of it to get it off, very lucky day, LOL
old magnet, i think i found the problem. some fellow who didn't have a book or access to the intenet got carried away with the shims. take a look, get rid of the shims and everything will go back to centre, or be very close.
thansk
17 years 8 months ago #2338
Hi KoO,
No wonder the bugger was out of align. LOL You didn't read me the fine print.
Dropped on its side will do it every time. Glad to see you are making her right again, at least as close as possible. Not to tight up against that dead axle nut I hope.
Dirt Dog, I think there is some confusion. The coupling can be removed one of two ways. Two 5/8 jack bolts through the coupler pushing against the heads of two bolts for the bearing cage or use the stubby hydraulic cylinder and puller bar. I believe it was the bearing race that got the torch job. KoO, did I get it right?
17 years 8 months ago #2340
by King of Obsolete
yes old magnet, it was the bearing race, if i had screwed it up, then 2 more days to pull the crown gear shaft, got lucky,LOL
yes the track frame arm is right against the dead axle nut, so i'll remove the shims and it will have enough room. like to know where the fellow got all the shims from, LOL they are all the same thickness so they were bought at caterpillar, LOL i hope the fellow was not the head mechanic for a fleet of winter freighting cats. think of all the sprockets that are woren on one side plus all the shims that were order from caterpillar (capterpillar parts man must have stocked up on shims because this fellow was ordering every week. once he got fired, caterpillar parts man never sold a shim in 10 years, LOL)
thansk
17 years 8 months ago #2341
by Dirt Dog
Koo and OM - thanx, the coupling was what I was curious about, I understand now.
dd
My pullin' site
17 years 8 months ago #2363
by King of Obsolete
well is was a good day in the KINGDOM with a little welding happening. i welded up the saddle and got it all straight. plus it was warm enough for the loader out and bring up a few spare parts, LOL
thansk
Time to create page: 0.195 seconds
