Hanna the Grader gets new glass (and decal question)
3 years 5 months ago - 3 years 5 months ago #227808 by Onfoot
Today launched the beginning of the aesthetic phase of Hanna's rejuvenation process, replacing all the cracked glass in the cab. The fellow removing the door glass is a journeyman glazier, providing glazing service to heavy equipment all over Yukon, Northern BC and parts of Alberta. Great fun to watch someone who really knows their stuff. And I learned a lot, too.
The more observant among readers may notice that the decal says 14E, when Hanna is a 12F. The story behind that is the previous owner's having a contract that would not allow Cat 12's for the job. (Too old? I have no idea.) So he turned his 12F into a 14E. Easy peasy!  Which raises a question: Where might one source a 12F decal?
Finally, is there a recommended source for old Caterpillar yellow? (=12.0ptCat # 4C-4185, PPG# 80453 Dupont # 421A are the paint codes I found on the site.) I'm only looking for a spray can or two at this point.
Thanks as always!
Last edit: 3 years 5 months ago by Onfoot. Reason: grammar edit
3 years 5 months ago #227810 by Onfoot
I've found a few decal sources online, prices ranging from USD$75 to $155 for a set that includes much more than I need. (I'm just looking for the two decals on the side of the cab.) One source, www.esignsplus.com, will sell a set of the cab side decals (2 big 'C's and 2 big 12Fs) for USD$49.85 all in. Would prefer to buy from ACMOC if a 12F set was available, but 12Fs are not listed on their order sheet.
3 years 5 months ago - 3 years 5 months ago #227813 by D4Jim
Was the Caterpillar "C" decal an original on your grader? I can't remember when the "C" came into existence but I thought it was in the 60's. I have had good luck buying transfer decals for a scraper on line and only later found out they were the same as on other Caterpillars through ACMOC. Great that you found a guy that can fit the glass in Hanna. My grader windows looked like yours after we had a horrific hail storm here in Kansas and it was difficult to find anyone to replace the glass. As for paint I have not been a purist but have used Highway Yellow that I got years ago through Rustoleum that seems to be very close to the Cat Yellow. There are others on the board that know a lot more about paint than I do. I'm net even sure when Cat went to the modern yellow.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 3 years 5 months ago by D4Jim.
3 years 5 months ago #227814 by Onfoot
The Caterpillar C decal is original on the '68 12F's. At least all the photos I see of equivalent machines sport the C. You've got an interesting stable machines, D4Jiim!
3 years 4 months ago #227852 by Fat Dan
MUST READ
This should give you some help and warning .. a sensitive area to be leaking
ACMOC Membership
The following user(s) said Thank You: Onfoot
3 years 4 months ago - 3 years 4 months ago #227853 by Fat Dan
        Few more tid bits of info
ACMOC Membership
Last edit: 3 years 4 months ago by Fat Dan.
3 years 4 months ago #227854 by Fat Dan
Sorry this new format has me running in circles ...or is yours the power shift? S/N 89H ?
ACMOC Membership
3 years 4 months ago #227855 by Onfoot
Not sure what having a power shift would indicate. (Did I mention that I am a newbie at all this?) But my S/N is 59H498. So if the 89H's have power shifts, than that must be what I have. All I know is that I have a clutch and two gear shift levers. One lever shifts between high and low range. The other shifts between 3 speeds forward and 3 speeds reverse. (For a total of 6 speeds in total in high and low range.)
To what would the 'power' in power shift refer?
3 years 4 months ago #227856 by D4Jim
If it is a power shift there will be small console next to the drivers seat and if it is a direct drive there will be two long shift levers coming out of the floor boards. PS means one can shift gears under load without needing to stop and change gears. I have driven both but don't know the exact designations.
D47U 1950 #10164
3 years 4 months ago #227857 by Onfoot
In that case, it is most definitely NOT a power shift. There are two long levers coming out of the floor and no small console next to the driver's seat. And it is definitely not possible to shift gears under a load. Thanks, D4Jim.
