- Thank you received: 153
It then shows the clutch cover (one with fill cap next to oil level stick) off, and the locknuts / adjusting ring looking through the cover to the front of the tractor. I did see the tab you pointed to the other day Daryl through the same location.The proper clutch adjustment will give a clutch lever pull of approximately 35 pounds. This measurement is made with a spring scale placed at the bottom of the handle on the clutch control lever with the engine stopped and when the clutch is cold. Slightly higher pounds pull may be required when the clutch is warm. Clutch lever pull will reduce when the engine is running, however when the clutch is properly adjusted the lever should go into the engaged position with a distinct snap. The clutch adjustment should be checked every 500 service hours and adjusted if necessary.
It doesn't describe how to "turn the flywheel" ...Turn the flywheel until one of the adjustment nuts (2) is accessible. Loosen the nut about two turns. Tap plate slightly to be sure it is free on stud. Rotate flywheel 180 degrees and loosen the other locking nut in same manner.
All the oils I use are in spec for the machine so good there.That is not the correct adjustment for an oil clutch, there are two tabs with 3/8" nuts on them opposite sides of the clutch plate ring, loosen those and turn the inner plate until the correct lever pull is obtained, retighten nuts. Use 30W drive train oil for the clutch.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
