what model is my 950 loader
3 years 5 months ago #227663
by Yukon950
Hi guys. I am very new to all this, but happy to be a part of the community.
I have a 1968 950 loader, SN 58H515. Photo attached. Can anyone tell me what the model is?
Many thanks!
hfdzl
3 years 5 months ago #227666
You've already identified it. A model 950 wheel loader built in 1968 with D330A engine.
Built in Canada same as 90Axxxx US model.
3 years 5 months ago #227668
by Yukon950
Forgive for not repleying emedeitly.i'm trying to learn computor.i thankyou too much for your knowing of cat equipment=my wife helps me also a good friend with this instrument=I'M greatfull.now i know how to order parts.you have a good one.
Onfoot
Thank you received: 54
3 years 5 months ago #227677
by Onfoot
Well done, Yukon950. And welcome to the ACMOC forum. I know you have a huge amount of experience and wisdom to add to some of the discussions.
Fat Dan
Thank you received: 279
3 years 5 months ago #227680
by Deas Plant.
Hi, Yukon950.
Unless I am mistaken, that would be the "A" series of the 950 loader line - WUNN TUFF MACHINE. I got to operate a couple of them. Have fun.
Thank you received: 409
3 years 5 months ago #227681
Not sure if what you meant was which of the multiple series of that model it is, but from my untrained eye, it looks like the first series produced in the 950 model range. I'm only saying that based on the cab arrangement. I drove a 950B loading logs in the 80s for a while and yours does not look like the same cab
3 years 5 months ago #227703
by Yukon950
I want to thank you Neil for your information=I just know enough about this loader to get me in trouble=
3 years 5 months ago #227705
by Yukon950
Neil i should have mention that Magnet told me the loader was a 'a' model loader=thank you both=
2 years 10 months ago #232752
by Yukon950
Good day Gentlemen=The name is Yukon Bob=I own a 1968 950 loader=Problems with the air compressor=removed and checked unloader poppet valves=This compressor has been over worked from a few air leaks=Delivery valves springs are weak and one broken from over heating=Cat compressor I believe it is a Bendex Westinghouse Cat P/N is 9M5475 number TU-FLO 300=I under stand from another Gentleman that a TU-FLO 400 can also be used=I'm in need of a compressor an exchange unit or a rebuild kit=This compressor is a pulley and belt driven=
Thank you received: 341
2 years 10 months ago #232760
by edb
Hi Bob,
if you have no success with your above requests Down Under here at our Cat Dealer we used to purchase some parts from our parts department and also a local on highway truck repair shop that specialized in brake systems.
Mainly we sent the barrels/cylinders or blocks to them for boring out over size and then get them to supply the overhaul kit and oversize pistons and rings to suit.
Hope this helps.
Time to create page: 0.196 seconds
