D4d cat 82j2818 fuel shutoff switch?
Thank you received: 620
Thank you received: 409
3 years 5 months ago #227490
Bruce, it has a detent at low idle, you have to give the lever a shove past that detent to reach shut-off
Thank you received: 387
3 years 4 months ago #228116
if its like the 6/7u models there is also a detent for full throttle if you go past that you get full fuel for starting. i didnt know about that until someone showed me, it started much easier after that.
Thank you received: 67
3 years 4 months ago #228135
by kittyman1
that's interesting, a full throttle detent for starting a diesel?? for at least a couple reasons, maybe more....
1) in my experience, i've never found full throttle to be better starting a cold diesel engine or gasoline..
2) i don't like shrapnel flying about and picking up pieces and putting them in a bucket etc...
3 years 4 months ago #228335
its sort of like choke on a petrol.
all computerised engines do it automatically and as soon as it fires deliver normal fuel amounts. even the mechanical bosch ve type pump on the old ute does it but its regulated by coolant temp and a temp sensitive valve.
many older diesels start easier this way, you must be on the ball to throttle back straight away. lack of oil isnt a issue with pilot start cats as you will have built oil pressure before starting. yes it can be a issue with direct start equipment.
also remember the lever at the seat works different to the lever on the governor due to the linkage.
