14a main clutch hydraulic booster
3 years 5 months ago #227480
by doglicken
i need some help. I have a 14A with a wet clutch and a "hydraulic control mechanism" (that is what they call it in the manual).
So when you pull the clutch lever back to engage the clutch they "hydraulic control mechanism" assists in engaging and disengaging the cluch. There is an 1/8 inch port in the top of the "hydraulic contol mechanism" that you can screw a gauge into.
I have the following questions:
1) With the clutch engaged and the engine running should the hydraulic pressure meausered at the port of the "hydraulic control mechanism" be consistent at 350 psi?
2) Or does it only maintain pressure when engaging and disengaging the clutch?
3) Is the pressure also used to maintain pressure between the clutch and flywheel?
3 years 5 months ago #227496
There is only one pump that supplies circulating oil to the main clutch and the booster and runs continuously. A pressure relief valve limits the pressure to 350 psi. I would expect to see full pressure to the supply side of the booster whether the clutch is disensgaged or not.
Thank you received: 341
3 years 5 months ago #227507
by edb
as OM says the system is limited to 350 +/- 10 PSI by a relief valve.
The oil pump supplies oil for clutch lubrication and cooling at low pressure as well as up to the set pressure whenever the clutch lever is moved back to engage the clutch and/or is held there--you would likely build to full RV (Relief Valve) pressure in this mode.
Reading the Service Magazine (June 30, 1953) that my scanner will not copy at present, it seems that when the clutch lever is moved back to engage the clutch the control valve moves and pressure in the system rises until it either reaches the set pressure of the RV or engages the clutch at the pressure required to meet the adjusted clamping force the clutch was last adjusted to (a higher pressure but not necessarily maximum RV pressure) or worn down too (a still lower pressure than the RV setting)
There is provision to still supply some oil to the clutch lube system when engaging or disengaging--when I get to post the scans it will become clearer.
There is little pressure assist in disengaging the clutch to save excessive forces on the clutch release mechanism and clutch brake as the operator pushes forward on the clutch lever.
Hope this helps.
3 years 5 months ago #227509
by doglicken
thanks for your input.
So here is what I have done. I screwed a gauge into the port on the hydraulic control mechanism. When I engage the clutch i pull back on the lever and after the clutch is engaged i dont have pressure at the port. If i pull the clutch lever moving the servo in the pistion of the hydraulic control mechanism (about 1/2 inch) pressure builds to 350 and i can hear the pressure relief valve open. if i release the clutch lever the pressure drops back down. The servo is spring loaded and returns back 1/2 inch opening the port that releases the pressure. I assume that this is normal? Is it?
Does the hydraulic control mechanism only aid in engaging and disengaging the clutch? It doesnt maintain pressure against the clutch discs correct?
i think that the mechanical linkage is what maintains pressure on the clutch discs not the hydraulic pressure. is this correct?
They hydraulic systems that I have been around dont maintain pressure at the rated pressure until a port is closed which allows pressure to build. But after the task is completed the pressure doesnt maintain and bypass through the pressure relief valve, the valve is released and the oil flows as volume but not under pressure. Im thinking that it would be the same on this hydraulic control mechanism.
thanks
3 years 5 months ago #227512
Correct, hydraulic pressure is not used as a clamping force for the clutch. Oil is only circulated to supply cooling and lubrication to the clutch mechanism that operates as an over center clamping force.
3 years 5 months ago #227513
by edb
your assumptions above appear correct as per the descriptions detailed in the Construction and Operation section in the scans below.
Yes, the clutch stays clamped/engaged by vitue of the cam over centre action of the links, rollers, and counterweights as is the normal way Cat uses to operate and clamp their clutches in most model machines. The hydraulic cylinder is only a booster used during engagement and disengagement of the clutch assembly.
Here are the scans of the Service Magazine June 30 1953 detailing the new D8 Oil Clutch and its operation.
First excerpt scan is what I tried to explain above and is from page 5 of the series, right hand side of page between the photos.
Hope this helps.
3 years 5 months ago #227539
by doglicken
can you tell me what the initial setting is on the main clutch. I've read in the operators manual that it is 120 to 130 lbs of pull below the handle on the clutch lever and Ive read in the repair manual that it is 25-35 lbs of pull. can you tell me which is correct?
3 years 5 months ago #227541
The 120 - 130 lbs is for the 14A (Direct Drive)
The lower rate is for the 15A (Torque Converter) drive.
Two different types of oil clutch.
3 years 5 months ago #227547
by edb
Hi,
my grey Operation & Maintenance Instruction, Form No 31390, Dated 03/55, which covers both the 14A and 15A machines tells me the initial adjustment before wear for the 14A is 140 lbs pull, measured with spring balance below the operators handle, cold and with the engine stopped--ie, no hydraulic boost.
The 15A is different and is 11 to 21 Lbs measured as per the above method.
As I do not have a 14A Service Manual but do have some Specifications from Service Manual inserts that do not give a lbs pull spec. for the 14A, BUT, does give the 15A as 11 to 22 lbs again.
So by the above data I would adjust your 14A to 140 lbs pull, cold and engine stopped--maybe the lesser figure is with engine running which would be less as hydraulic boost would come into play and lessen the actual felt/perceived lbs pull at the clutch lever.
I stand to be corrected.
Time to create page: 0.193 seconds
