forklift forks for dozer?
Thank you received: 620
3 years 5 months ago #227449
by Rome K/G
That JD forklift does not have a spring on the front it is a rigid non oscillating frame.
Thank you received: 279
Thank you received: 13
3 years 5 months ago #227453
by greengiant
I might have the local welding shop fabricate something. another good use for forks would be to move pallets. the last time I had to move a pallet with a pony motor strapped to it I had to drag and push it, not cool.
Thank you received: 409
3 years 5 months ago #227457
What weight are you looking to lift? If it's down in the 500# range, you can use a garden tractor 3pt with hydraulic top link for tilt. Couple of guys on the JD mower site have them and swear by them. Garden tractor is easy to move around and park etc - with the right attachments, they're very handy and cheap
Thank you received: 387
3 years 5 months ago #227466
deas makes a good point id forgotten about that.its the same with a simple fork frame mounted on a tractors 3 point linkage the lift in a arc not straight up and down.but a tree spear could work nicely as a lift jib with some sort of mechanical grab or you use a length of chain fitted with grab hook as a snotter(choker). to make a snotter you loop the chain around the log and then around the chain and back on itself this form a self tightening strangle hold that wont fall off easily until you want it too by letting the weight off and unhooking the hook this method has been used for decades by timber cutters to snig logs behing tractor etc i have personally used it to snig a couple of logs together and to lift posts into post holes. i have even used it on steel posts too to reposition it in concrete that was setting, the post had settled to much. yes iknow i cant draw well but you get the idea.
2 years 1 month ago - 2 years 4 weeks ago #240107
by georgianacrouse
I’ve seen tractors with telescopic frontal loaders that used a forklift to load and unload trucks. It was perfect for pallets, and there is nothing that you could change this tractor with.
I think you might be interested in getting one of these. I would recommend
rent forklifts
before buying them to see how well they work and how much you need them in your business. It is the best solution for small businesses that don’t have a system and want to figure out what they need for the most effective work. And only after renting can you proceed to buy one.
2 years 1 month ago #240120
by Peter C
This has a set of lift forks that go with it. The owner passed away about 12 years ago but this was reportedly used with the forks to move logs at his sawmill. I haven't seen the forks to know whether they were homemade.
Pete
Time to create page: 0.169 seconds
