OFF TOPIC Johnson 80-C Scraper
Thank you received: 191
3 years 5 months ago #227324
by D4Jim
Does anyone know anything about these elevating scrapers? This one is for sale not to far from me and the price is right so seriously considering it to use with one of the farm tractors. Don't know anything about them and don't recall ever seeing one before.
www.purplewave.com/auction/210408/item/D..._Type_Scraper-Kansas
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 9
3 years 5 months ago #227325
by TOGNOT
They are very handy, I can say from experience. One thing to consider, ( I’m no xpurt) is it equipped with low pressure hydraulics or high pressure ?
In other words, will your modern tractor run it ?
Thank you received: 279
3 years 5 months ago #227327
by Deas Plant.
Hi, D4Jim.
I don't know anything about that particular model but Caterpillar chose Johnson to make the elevators and scraper bowls for the Caterpillar J621 scrapers, the "J" being for Johnson. Those rigs were pretty reliable and effective.
TOGNOT has raised a pretty important question regarding the hydraulics. If they are low pressure hydraulics, it might work behind a D6 up to maybe an early D6C but you would need to have the power take-off available to drive the elevator. I have no idea what wheel tractors might handle it - don't hava whole lotta experience in that field..
Thank you received: 15
3 years 5 months ago #227341
by Glum
My father had one that he pulled behind a JD 4020 in the 80's building farm dams. Can't vouch that it is the same model but looks identical. Was a bit young to remember much about it myself but he always preferred it to the open bowl pull scrapers. Always said that if he'd kept it longer he would have converted the elevator to hydraulic motor driven.
3 years 5 months ago #227358
by D4Jim
Thanks for the good suggestions and questions to ask. Plan to pull it with an older 4440 I have that is power shift and I think it is about 130hp. I don't think the elevator PTO part will take much power but I think hydro motor drive would be much simpler. My experience is the elevating scrapers are a lot easier to "load" than the bowl scrapers. The hydraulics are compatible with my 4440.
D47U 1950 #10164
Thank you received: 251
3 years 5 months ago #227400
by juiceman
Well Jim, I hope you buy the Johnson scraper. I will call "dibs" on the Caterpillar #40 scraper should you decide to sell it. JM
Thank you received: 31
3 years 5 months ago #227402
by 17AFarmer
I can tell you we had a Case dealer in Turlock ca. That sold them, and there were Landlevelers pulling them with. 500 and 900 Case standard wheel tractors. Which was BIG Power in the 50s and early 60s. Those old Case’s were hand OIL Clutch which Case come out with in1929 Damed hard to wear out!!! 17afarmer
Time to create page: 0.161 seconds
