No. of teeth / diameter D2 vs. D3 weld-on sprocket rims
Thank you received: 409
3 years 5 months ago #227297
Hi, the D2 weld-on sprocket rim is 7H0463 (bushing dia. 1.69"), and the first series D3 rim is 6Y1244 (bushing dia. 1.85"). I would like to know the diameter and/or # of teeth each of these rims have. Contemplating going full D3 rollers, rails, sprockets on my 5U and need to know if this is feasible, as I'm thinking about the sprocket-to-track frame / rear roller clearance
__PRESENT
Thank you received: 341
3 years 5 months ago #227301
by edb
Hi Neil,
I do not know if the scan below helps or not.
hfdzl
3 years 5 months ago #227302
The back roller/s on the D2 are cut out to receive the sprocket, D3 rollers do not have the cut out so they need to be moved forward to clear. (about 1 inch)
3 years 5 months ago #227304
Thank you both for that information. Looks like the 6Y1244 is marginally smaller than the 7H0463 so that helps.
Time to create page: 0.125 seconds
