scored a D2
3 years 3 months ago #229183 by neil
Replied by neil on topic scored a D2
Great job! Two running engines, a usable main clutch, and one steering clutch means it's mobile, at least for fixing. I agree with Mike, it seems like that right side clutch needs to be pulled:
- split track at master link
- undo pivot shaft nuts/bolts on right side main cap underneath the transmission. I think the dowel is on the left side case so you might not have to do anything further regarding the pivot shaft
- jack tractor up on that side, or the entire back end so's the sprocket clears the rail and the pivot shaft sags a bit from the final assembly
- undo the 3/8 nuts/bolts that hold the final drive assembly on to the main transmission case
- using an engine hoist or your overhead crane, lift, wiggle, tap, swear at, and generally finess the assembly off the main case. There are a couple of binding points - unsticking the assembly from the gasket from the main transmission case, sliding the assembly off the two dowels, sliding the outer/brake hub that is part of the final assembly off the clutch plate "fingers", sliding the sprocket shaft inner bearing out from the main transmission case boss it sits in, and sliding the assembly off the pivot shaft. So, it will seem like it's stuck but it's just a whole set of things combined to make it seem that way. My technique was to use a paint scraper to go around splitting the gasket (Cat has new), tapping the dowels while pulling the assembly to free them them up in the holes, fully removing the pivot shaft but that's a whole extra piece of work, maintaining a steady outward pull while tapping and wiggling etc. Once it was a bit loose, I also cocked the assembly over, and then turned the sprocket/gears so that it kind of worked the clutch plate in the splines to further loosen up rust etc. Took me a couple of days..... Of course now that everything is new and well-oiled, I imagine that it would slip off like butter on toast : )
3 years 3 months ago #229187 by Jknarfal
Replied by Jknarfal on topic scored a D2
I'm really hoping not to have to tear it down that far. I'm not looking to work this thing. More of a collectors item. I have more modern equipment if I need something to work. Just ran it around a bit hoping it would free up with no luck.
Ten, fifteen, D2-3j, D2-3j wide, D2-5j, RD-4 4g, D-7 7m, D8-2u.
3 years 3 months ago #229188 by yellowredox
Replied by yellowredox on topic scored a D2
I don't think there is anyway its going to get free aside from taking it apart. My D2 was less rusty than yours, and I tried everything to free the steering clutches with no success. Finally took it apart...broke the drum getting it apart...I was astonished how solidly everything was rusted up-I can see why nothing worked!
3 years 3 months ago #229199 by neil
From my experience with my 5U, that amount of rust likely means the bearings are toast. Once the bearing gives enough, components will break. I think it's a better prospect to pull it apart, replace the clutch components and bearings, then it'll be safe and it will work properly. It's really not that bad of a job but I hear you on the need to prioritize other things - that's why my 5U is still not finished after years! : )
3 years 3 months ago #229208 by Steve A
Replied by Steve A on topic scored a D2
Great progress, tie back the stuck clutch hook to a load, drag or disk, whatever and go pull it around a field for a couple of hours, I have even done this with 5 gallons of old diesel in the compartment. even if it doesn't come loose it will improve your odds of pulling final drive with out breaking the drum.
3 years 3 months ago #229209 by Mike Meyer
Replied by Mike Meyer on topic scored a D2
Steves advice is very sound, find the biggest, heaviest thing that D2 will pull, and fill the compartment with diesel.
My RD6 was full of water on one side when I dragged her home, I filled the compartment with citric acid for a few weeks, even put a fish tank pump in there to circulate the acid.
After the acid soak I tied that steering clutch lever back and hooked the tractor to a big heavy log and dragged that for a few hours with my foot on the brake pedal, I had smoke pouring out of the compartment, it still didn't pop loose, so I chained the tractor to a tree and put her in first gear with the good clutch disengaged, that worked. I figured I had nothing to lose.
That's where you are right now, try the easy things first, if they don't work then fix it or sell it.
Time to create page: 0.188 seconds
