D2 top carrier rollers
Thank you received: 50
3 years 5 months ago #227061
by hfdzl
I amm updating my project D2 to top carrier track rollers. What would be the new Cat part number that interchanges? Or aftermarket
I have the brackets, need to obtain roller assys to press in.
Thanks, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 409
3 years 5 months ago #227068
Hi Herb, I don't have updated numbers - just the original number from the parts catalog - do you need that? And what's your serial # in case there's a break
3 years 5 months ago #227081
by hfdzl
Hi Neil, I have books and more books. Just curious if anyone did this same procedure, and had a newer interchange number.
3 years 5 months ago #227084
I'm planning to put D3 rollers on my 5U, including the carrier rollers. The D3 carrier is the roller and a plain round shaft stub that sticks out and is clamped into the carrier stand on the D3. I think that means I need to adapt the top half of the D3 stand to fit my D2 track frames. I might just even make a stand out of some thick wall tube and a plate. The clamp should just be a tube sliced down the side with a bolt hole "attached". Not sure if that's anywhere near what you're doing?
3 years 5 months ago #227091
by hfdzl
I found a couple actual D2 carrier brackets. Just putting new rollers in, looks like smaller excavator and D5 will fit.
Thank you received: 620
3 years 5 months ago #227101
by hfdzl
Ya, thanks for the update. I thing the '53 5U is a lot more classy!
3 years 5 months ago #227102
Looks like I can add the cab attachment to my 5U now with a/c and a radio : )
3 years 5 months ago #227121
by Rome K/G
Yea for probably around 20K
Time to create page: 0.145 seconds
