Thoughts on making a D2 track press
Thank you received: 387
3 years 5 months ago #227258
yes as phil has mentioned be careful with threaded rod the cheap stuff which is often made in china isnt true to size as they often start with bar the size of the thread not bar to make that thread and therefore after machining as most threaded rod is roll formed and not cut it ends up undersize. be sure your buying quality high tensile rod from reputable companies that actually does meet the standards for structural use its is made from the correct oversize bar stock and rolled or cut to size
there has been some building failures due to companies short cutting and using the inferior product one was a suspended walk way in a shopping centre in the US the cheap rod just pulled out of the fasteners as the threads had very poor thread engagement due to being under size.
that is why i use rod supplied by bremick, ajax fastners or hobson engineering.
Thank you received: 409
3 years 5 months ago #227263
Yeah I only buy quality from either Cat or Fastenal - I do buy hardware grade as well but only in situations where it doesn't matter, like putting up the kids' shelves : )
Thank you received: 63
3 years 5 months ago #227280
by PhilC
Thanks for that information Phil. Looks like I might need to add a 30t ram to my collection. The vendor I bought my set from has an extensive range of ram tonnages, and physical dimensions so I'll find something that works best
You could always try it first before spending money on another cylinder. Just make sure youaccount for the bigger cyilinder when you make your plates up. Maybe Eddie might have a chart that would show the force required for track pin removal.
3 years 5 months ago #227283
Yes that's exactly what I thought. I've looked up the Hydrafore options and have the 30t 6" stroke ram outside diameter so the bolt spacing will be wide enough to accommodate that should I need it.
Thank you received: 183
3 years 5 months ago #227284
by d2gary
Hey Neil can you provide the measurement for the 30 ton cylinder diameter. I'm making a rudimentary pin press to aid in installing my d2 tracks. I have a hyrafore 20 ton cylinder that measures 4 in diameter but feel like a 30 ton might come in handy for some upcoming d4 track work. I can alter my holes to accommodate a bigger cylinder now without compromising the strength but would be more $$$ later to make more plates. I already have 1 inch grade 8 domestic threaded rods and nuts. I'm going with 1 inch plate.
3 years 5 months ago #227308
by d2gary
Thanks Neil i ordered the standard 30 ton cylinder. Hopefully everything will show up so I can install the spring and tracks next week.
3 years 5 months ago #227318
Scott, you do not let the grass grow under your feet do you? : ) Must be a show you're getting ready for?
3 years 5 months ago #227326
by d2gary
Neil i hate grass growing under my feet and my friend Bryon aka markus meticulous is having a gathering this summer with his 1905 sawmills and has requested my d2 to be present. I'm pretty motivated but when someone throws down the gauntlet I'm on it. I am going to get this tractor going and if not I told him ill drag it over there with one of the d4s so it can look pretty. But it'll be running for sure
Tracks on next week fingers crossed after that things should progress as fast as the honeydew list will allow 👍
Thank you received: 48
3 years 5 months ago #227538
by mog5858
well, I will say that I used 1"NC grade 8 all thread all the time at work to 30 tons to pull things apart that. one 1"nc will hold 30 tons I would stay away from fine there as they get damages so easy when being used. I like and use a lot of 4140 htsr it up there over 100,000 vers the 56,000 of 1018 mild steel. find some old grader blade or old corner bit of a dozer blade good steel and they have holes already in them. steel keeps going up but the week/day sometimes. I would say steel double in price in the last 18 months. 2" is overkill if you ask me . sometimes we can make stuff so heavy you can move it or adjust it in place without a crane just keep that in mind I have done that my self.
Time to create page: 0.202 seconds
