Recoil spring bolts D2 5U
Thank you received: 50
3 years 5 months ago #226929
by hfdzl
Anyone have experience in dissasembling the heavy track recoil springs? Both of the bolts are stripped out. I can make the bolts and nuts. I want to be safe when taking these apart.
Thanks, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 409
3 years 5 months ago #226930
I don't Herb but I've heard people say they sacrifice the spring. Rather than that (because I'm not good at throwing away stuff : ), you could find a press big enough to fit the spring in and just "take the weight". You wouldn't really need to compress it more than 010 because all you need to do is slice the nut off with the gas axe then let the pressure off the spring. Anyway, that's what I'd do.
3 years 5 months ago #226931
by hfdzl
I'd rather not cut the spring. . I think what I will do is run a couple 1 1/4 heavy nuts on the bolt and then do the same to 'catch' the spring with an inch of release space. It'll work.
Your bracket is in the mail.
Thanks, Herb
3 years 5 months ago #226933
Thanks Herb, I just saw your PMs, check will be in the mail. I'll have to ask IT to make that font bigger so I can see that I have messages : )
Thank you received: 183
3 years 5 months ago #226936
by d2gary
When I did the ones on my 5t I put them in the press to hold the tension and cut the nut off. I also ran some threaded rod through the ears on the flanges as a safety measure. They don't really expand as much as you would think, maybe 2 0r 3 inches.
I would never sacrifice the spring.
3 years 5 months ago - 3 years 5 months ago #227029
by hfdzl
Gary, I put the D2 springs in the press and cut the nuts off there. The pressure gauge is hard to read at the bottom of the scale but looked like 3 or 4 ton. Only had 2 1/2 in of compression. Welded new threaded end on the square head spring bolt. Should be fine. New Cat bolt is supposed $280
Last edit: 3 years 5 months ago by
hfdzl.
3 years 5 months ago #227035
by d2gary
That should work fine. Cat is pretty proud of some of their stuff. I had new made for less than half of Cat price.
Time to create page: 0.153 seconds
