ran out of desil
ran out of desil
3 years 5 months ago #226895
by rouger
I am seeking help on how to reprime my D47U 1959 .....i lost fuel pressure after tank ran dry .....How do i go about repriming my lines?
Thank you received: 31
3 years 5 months ago #226896
by oldbeek
Are you near your shop or out in a field?
Thank you received: 191
3 years 5 months ago #226898
by D4Jim
First on the list, fill the fuel tank!!
(assuming a leaky fuel tank was not the problem)
If you have a manual, follow the priming procedure in it basically working from the tank to the injectors. All air has to be removed from the fuel lines. If you don't have a manual we can post a page with the info.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 409
3 years 5 months ago #226900
Steps:
1. Fill tank - ideally completely full
2. Verify tank valve is open
3. Open bleeder valves on fuel filter tower
- optional: apply no more than 5psi air pressure to fuel tank to assist with pushing fuel through
4. Open bleeder valves on injection pumps (4 of) - special socket or wrench is recommended but a 1/4" open wrench can substitute
5. Set the main governor control to off
6. If you have a pony start, turn over main engine with decompression. This will operate the fuel transfer pump to assist with pushing fuel through the system but the fuel will likely flow anyway with a full tank and air pressure
7. When a steady stream of fuel with no air bubbles emits from the filter tower bleeder, close them
8. When a steady stream of fuel with no air bubbles emits from the injection pump bleeders, close them
9. Open governor control and start main engine
Thank you received: 22
3 years 5 months ago #226943
by TomTrack44
Nicley done Niel, wish I had this list last year when I ran my D6 out of fuel out in the pasture. Got it going but not without a lot of bad words!! Following your description would have been so much Thank you, Tom.
Thank you received: 251
3 years 5 months ago #226950
No problem Tom, I was half expecting someone to chime in with a step that I forgot or got bass-ackwards! : )
3 years 5 months ago #227031
by rouger
thank you for all your help .....I have fuel pressure agian and and lots of fuel to the injectors .....puffing white smoke agian at stack.......batteries were to low to give it a proper roll and weather is still a little cold in my area today so didnt want to push it
3 years 5 months ago #227032
by rouger
The adding air pressure to the tank most definatly was a huge help.......i took a piece off inner tube and stem and just gear clamped over the tank fill
ran out of desil
Time to create page: 0.170 seconds
