ID pto and BeGe
ID pto and BeGe
Thank you received: 21
3 years 6 months ago #226664
by Mschwartz
Picked up a PTO and a BeGe set at a sale and would like some help to identify. I think the pto is for a 7j d4 but will it interchange with any other model? What does the pattern of the BeGe housing look like it will fit? Thanks, Mike
Thank you received: 10
Thank you received: 57
3 years 6 months ago #226667
by Wombat
Without physically seeing them, I am thinking they may fit an S or PS THIRTY.
Wombat
Thank you received: 118
3 years 6 months ago #226668
by Ray54
The mount on the pump is the right bolt pattern for D4. But needs more length to get it out behind the seat. But AC HD 5 and IH TD 9 both have the same bolt pattern and the seats don't overhang the case so could fit ether. But the drive shaft would need to be different for each I think.
Doing more thinking does the D4 C and D still have that bolt pattern on case. Because there seats don't hang out the back ether.
Thank you received: 251
3 years 6 months ago #226669
by juiceman
That should fit a U, C or D series D4. To get more seat/tank clearance, sometimes an in/out box I call them will do it. Lever position makes a difference too, if you’re not using the tower style, say cable controls, only worry is having the oil reservoir fit under the tank.
AC bolt pattern is reversed, wider on bottom than top.
An IH uses a much longer snout base from what I’ve seen. Nice find on both items.
Thank you received: 153
3 years 6 months ago - 3 years 6 months ago #226672
by rax200
Hi Mschwartz,
The pto is of a D4 u series as per the parts cataloge.
Nice find there
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 3 years 6 months ago by
rax200.
3 years 6 months ago #226676
by Mschwartz
Thanks everyone for helping me on this. I will check my 20j d4 later today and see what the rear cover looks like. Would be great if that would be an option, my 7j already has a Hyster D4 winch on it. Might have to find a 7U to add to the operation. Neighbor has some td6 and TD 9 tractors I will look at them and see if I can determine if that is a match for the Be Ge hydraulic system. Thanks again, Mike
Thank you received: 94
Thank you received: 22
3 years 6 months ago #226703
by Mschwartz
My D4D has the same bolt pattern on the back so I think that both the PTO and the BeGe hydraulic unit are for D4 cats. Wondering if the gearing might be newer for addressing the higher operating rpm’s of the newer tractors? Looks like other differences would be the engaging lever for the different series of D4’s. Thanks again, Mike
ID pto and BeGe
Time to create page: 0.214 seconds
