Cat D9G Power?
Cat D9G Power?
Thank you received: 5
3 years 6 months ago #226494
by gvanhouten
Hi guys,
Was working the old girl yesterday on some iron pines that have a pretty good root ball system and it just seems that the old girl just does not have the pushing power she should. I am thinking torque converter and or filters to check. All fluids are great. The engine is running very well but it seems that when I am up against a tree trying to push over the engine does not come up to full or half RPM. When I was pushing before she was a beast now she is a bit wimpy... Any suggestions or do you believe I am on the right track? Thanks guys hope everyone is well. George
Thank you received: 620
Thank you received: 67
3 years 6 months ago #226504
by kittyman1
as Rome suggested, a video would be best....we like videos..
-since we're talking diesel power, my first wild guess would be fuel system....lack of fuel...fuel restriction of some type, lines, filter(s) etc...
Thank you received: 409
3 years 6 months ago #226520
by Rome K/G
High idle rpm is 1455 +-30 rpm, 475 +-10 rpm, set decelerator at 700 +-50 rpm
I take it you already checked the rack and fuel pump lifter settings? If I remember that was an ordeal.
Fuel pressure good?
Check rpm at hour meter, that is half engine speed, or use a laser tach.
3 years 6 months ago #226522
Rome, is that decelerator setting the rpm that the engine should be at when the decelerator is fully depressed? In gear or neutral?
3 years 6 months ago #226526
by gvanhouten
I will be taking some video later today... Actually my wife will.... Yes, the rack was the first problem and then the rest.... Fuel pressure looks good starts right up... I am thinking maybe decelerator lever as engine just does not come to life with throttle fully open and decelerator engaged. When I lift my foot back engine does increase RPM of course in Forward 1 she moves and all just hard to get engine winding up. Thats why I thought torque converter first... I will take videos and post later today. Remember this is Hawaii so expect them tomorrow...
3 years 6 months ago #226527
Easy check would be that the decelerator really is releasing all the way and not holding back due to binding or interference. Does the engine go all the way to high idle in neutral? It can go to high idle but not be getting full fuel under load, which "usually" is because the rack is not opening all the way up under full load but it could also be intake restriction. If restricted, it would make black smoke (all the time, not just the rolling coal at acceleration : ). Could also be exhaust restriction.
Thank you received: 57
3 years 6 months ago #226531
by Wombat
How much oil in the converter case after shut down? There should not be much, if it is flooded it will act like a brake. This can be caused by converter failure, or scavenge pump failure or a blockage. Take a bucket underneath, you should only get about a gallon if all is ok.
best of luck, Wombat
Cat D9G Power?
Time to create page: 0.394 seconds
