D2 rebuild
D2 rebuild
Thank you received: 50
3 years 7 months ago #226233
by hfdzl
So, I seem to be going further down the rabbit hole as i get older! Nice-to me, little D2 The one with totally shot and frozen steering clutches and toatlly frozen main clutch, all courtesey of Mickey & Co. decorating and condo mananagers. Looking for a Rustoleum tan/brown ?? that is close to Cat inner compartment color. I understand that this for my personal enjoyment and actually does provide some rust prevenative purpose. Not going to paint match card level here.
Thanks!! Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 620
3 years 7 months ago #226251
by hfdzl
OK, Rome. Why not paint? Primer is porous. The real old Cats I restore, I use Gylptal red..
Thank you received: 46
3 years 7 months ago #226252
by dpendzic
Primer has better adhesion to bare or slightly rusted metaal
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
Thank you received: 183
3 years 7 months ago #226271
by d2gary
I've used the rustoleum primer on small block chevys, but any color primer will work. Its not there to seal the metal so much as it helps with oil return back to the bottom of the compartment. It also aids in preventing sludge build up as the sludge has a tendency to slide down instead of accumulate making it easier to drain it out the bottom during periodic maintenance.
3 years 7 months ago #226276
by hfdzl
Gary, that is the same purpose i use Gylptal electrical insulating coating. I want to coat steering clutch and main clutch compartments from further rust.
D2 rebuild
Time to create page: 0.155 seconds
