D4 Oil Clutch
D4 Oil Clutch
Thank you received: 153
3 years 7 months ago #225985
by rax200
Hi all,
Would some one the info on what oil and how many litres of oil is used in the D4 oil clutch SN 7U 37855 as it is not the owner hand book.
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 70
Thank you received: 620
3 years 7 months ago - 3 years 7 months ago #225992
by phildirt
Negative on transmission / drive train oil. Steering clutch compartments of 7U tractors are dry.
Crankcase Lubricating Oil to meet Cat specifications is used in the oil clutch.
Information from manual shown above.
Last edit: 3 years 7 months ago by
phildirt.
Thank you received: 409
3 years 7 months ago #225994
I occasionally wonder about TDTO in the dry steering clutch compartments on D2s and such. I think that topic has been discussed before but am curious if anyone has tried it, and whether it's worth a try. My steering clutches (5U) are new and use the sintered bronze plates and given TDTO is intended to not defeat friction in clutches, I wonder how it would affect the throwout bearing - thoughts?
3 years 7 months ago - 3 years 7 months ago #226000
by Rome K/G
I was refering to oil used in newer tractors that have wet clutches. Back then all they had was 30W engine oil
Rome K/G.
Thank you received: 118
3 years 7 months ago #226002
by Ray54
I believe Cat had a oil clutch update for the master clutch on the 6u and 7u tractors. I don't know when or if it would be in many of the operators books. Or was it a after market thing even. Just know a friend was very happy to find a 7u long track with oil master clutch. But he and tractor are long gone, so I cannot look at it.
No idea what oil was called for. The D6 of that time period calls for the same oil as used in the engine.
Thank you received: 341
3 years 7 months ago #226009
by edb
originally Crankcase Oil was the recommended oil for Master Clutches and Steering Clutches if applicable--now with all the super slippery additives in Engine Oil we should use TDTO4 (Transmission Drive Train Oil) so the clutch is less likely to slip even when adjusted correctly.
3 years 7 months ago - 3 years 7 months ago #226016
by rax200
Hi All
Thank you for the replies. I finally got this today good info.
Murphys Law, I post for some info and the the book finally turns up
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
rax200.
D4 Oil Clutch
Time to create page: 0.193 seconds
