she no workie workie
3 years 8 months ago #225361
by mhar
I got the bright Idea to fix what wasn't broke and changed the hoses on the dozer. The hoses have a set of quick releases on both sides. The blade got locked up in the down position. I released the the quick release on the down side and raised the blade hooked the quick releases up and it worked for a time but has locked up again. Do the quick have a flow direction? or any suggestions would help
3 years 8 months ago #225369
How old and worn are the quick release connectors. As things wear (balls & collars) the valves may not open for adequate flow.
Thank you received: 10
3 years 8 months ago #225376
by crookedwrench
We had the bright idea on our D2. Used a male end and a female end on each side. Did it carefully one at a time. Did the hydraulic rack at the same time. No way to hook them up wrong now. Works well. Even ran some long hoses from one side to a pull type plow. Is it possible that the hoses are not connected correctly??
mhar
Thank you received: 409
3 years 8 months ago #225382
That D2 would look brand new if it wasn't for the back of the fuel tank : )
mhar
Thank you received: 620
3 years 8 months ago #225398
by nomorejohndeere
some quick connectors are one way
don't ask how I know.........
D47U
AC HD3
nomore JD1010
nomore IH T340
mhar
3 years 8 months ago #225399
by mhar
I turned two hoses on the down side end over end and I was off to the races. Thank god was able to do some work today with the machine Thank you gents
Thank you received: 387
3 years 8 months ago #225490
that's called personal experience and development training
your family probably learnt some new words that day.
Time to create page: 0.167 seconds
