1953 D2 5U12237 Starting Engine Fuel Lines Replacement
3 years 8 months ago #225278 by Janner
I overhauled the starting engine. Putting the fuel lines back on, I've decided I'd like to replace them as they are dented, kinked, and the fittings hex flats are well rounded. Does anyone know of a good solution? I'd like to maintain the high integrity of the original lines (Stainless), but would like to convert to more modern fittings. Thank you.
3 years 8 months ago #225281 by Rome K/G
Coated brake line works good, you can still buy the flared ends from Cat, 4F9109
The following user(s) said Thank You: Janner
3 years 8 months ago #225287 by Old Magnet
I use copper/nickle brake line, doesn't corrode and work harden when you bend it. Use it with compression type hydraulic fittings, stainless is an option.
Time to create page: 0.141 seconds
