Huber Road Roller with Caterpillar engine
Thank you received: 10
3 years 7 months ago #225630
by caterpillarsam
i have seen many of the manuals on ebay but they all appear to be for different and newer rollers
i have been in contact with the Huber museum so fingers crossed they can find out some history on it
unfortunately the governor linkage arm has been broken off in the past and been replaced with some angle iron as can be seen in the photo
my next task is to pull the radiator, donkey engine (which does run but has a concerning amount of end play which will need to be addressed) and then pull the main engine
i will try to get as many photos for you all as possible
D2 3J
WW2 Huber three wheel road roller (D3400 engine)
1937 Twenty Two
Cat SCOTE engine
Allen Oxford drawbar grader
1944 D7 4T1154
D8 8R
1956 David Brown 25C
1954 DW-15 scraper 45C653
ag-mike
Thank you received: 183
3 years 7 months ago #225633
by d2gary
Open the can of worms and let the fun begin. Looks like a really cool project, finding d3400 parts probably won't be impossible but Huber roller parts might be challenging.
Everyone likes pictures!
3 years 7 months ago #225689
by caterpillarsam
Made some good progress today, radiator and donkey engine removed.
Tomorrow will be pulling the main engine
Very pleased with condition of everything so far.
Anyone have any spare D3400 radiator tags?
D2 3J
1937 Twenty Two
Cat SCOTE engine
1944 D7 4T1154
D8 8R
edb,
ag-mike
Thank you received: 43
3 years 7 months ago #225715
by caterpillarsam
D2 3J
1937 Twenty Two
Cat SCOTE engine
1944 D7 4T1154
D8 8R
edb,
ag-mike
3 years 7 months ago #225716
by caterpillarsam
succeeded in lifting the engine out of the roller today.
the weigh loader system on the road railer we used showed it a few kilos over 0.5ton of engine and bell housing
D2 3J
1937 Twenty Two
Cat SCOTE engine
1944 D7 4T1154
D8 8R
Thank you received: 409
3 years 7 months ago #225722
I like that the pony pinion is easily accessible. It would have been great if the tractors were like that
3 years 7 months ago #225728
by ag-mike
2me that's some impressive awesome i don't understand! 1000lbs seems light for that engine? Thanks 4 the pics, good luck with ur project!
Thank you received: 387
3 years 7 months ago - 3 years 7 months ago #225759
he's talking metric tonnes. a imperial ton (long tons) 1016kg or 2240 lb were as the us ton (short tons) is 907kg or 2000lb.
and if its dry it would weigh a bit less there's nearly 40kg just in coolant so without oil too i reckon around 60 to 70kg less.
Last edit: 3 years 7 months ago by
trainzkid88. Reason: more info
3 years 7 months ago #225764
Hi Mike, per Ron Nash:
"The basic engine with pony weighs 1890lbs. With a radiator attached .. and possibly the clutch as well? - you'd best allow about 2300lbs. The power unit fitted with enclosed clutch, radiator and sheet metal, and mounted on I-beam skids weighs 2770lbs"
so basically 1 ton give or take as caterpillarsam has it in the Huber. Sam, what was included in the weight? Radiator, pony, fluids?
Time to create page: 0.214 seconds
