D6 9U Repairs and Upgrades
Thank you received: 31
3 years 8 months ago #225009
by 17AFarmer
For a 9U find a D5 double element dry cleaner they will pickup some power and keep your engine cleaner PLUS back in the day they would get more Hours between overhauls!! Some of these old oil bath cleaners get the screens plugged with dirt not Good, I have hot tanked them before to clean them up. I have made this change several times. You wil NEVER be Sorry!!! I would not think about running oil bath cleaners again. 17afarmer
Xtremist
Thank you received: 11
3 years 8 months ago #225013
by Xtremist
so ill probably need to pick this up from CAT, or at least the canister housing for it.....would you happen to have part numbers by chance ?
3 years 8 months ago #225020
by 17AFarmer
I would not buy new I know 98j or older I am pretty sure D5B is the same, I used to have a D6B 44A I think it is the same. Call. Ed Miller 509 995 2317 I am SURE he will have what you need. 17afarmer
3 years 8 months ago #225023
Be aware that dry air intake filter elements have a shelf life of about a year. I'd recommend you stay with the oil version of only occasional use.
Thank you received: 341
3 years 8 months ago - 3 years 8 months ago #225034
by edb
Product Bulletin March 01 1960 gives data on the dry air cleaner field conversion amongst other data.
Alas I do not have a copy of the Special Instruction Form No 33577 mentioned for fitting instructions.
I also wonder if this unit might fit on the U D4--depending on clearance to the steer clutch levers etc.
Last edit: 3 years 8 months ago by
edb. Reason: Better Scan
Xtremist
Thank you received: 21
3 years 8 months ago #225094
by Mschwartz
Hello OM, just curious about the comment about dry elements only lasting a year? Never heard that mentioned before. Perhaps my purchasing nos cat filters at farm sales for my older cats is poor idea? All 5 of my 9U’s have been converted to D5 type dry elements, most likely when the turbos we’re added. Thanks, Mike
3 years 8 months ago #225096
by Xtremist
Hey Mike, would you mind throwing a few pictures up of your 9u's ? Im interested in seeing how they look with the turbo and upgraded filter setup. What turbo was used ?
Thank you received: 191
3 years 8 months ago #225115
by D4Jim
John Deere has the same stipulations, replace every year, Never mess with the secondary filter, Clean with air max of 6 times per year and of course replace it if there are any holes in the filter.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Xtremist
3 years 7 months ago #225618
by Xtremist
anyone have any recommendations on an "intake heater" like the attached picture ? would be going in the intake piping where the pony exhaust entered/exited to preheat the intake air a bit... 24v would be nice but im guessing that will be hard to find...
Time to create page: 0.186 seconds
