these sheets were posted on old BB but seems to be a number of requests for info on the subject requiring a re-post.
here is all I have on this subject.
One article is from a Service Magazine on the Full Flow Oil Filter System and another is a Special Instruction for Fitting Field Change Over Groups Form No (137--30605-1)--over the years some engines were or were not upgraded and still others seem to have mixed parts, likely due to confused information.
The typed Effective Adaptability From Serial Number sheets.
Hope this helps and not confuses things further.
Wow, Eddie, talk about good timing, was just going to try and work out what filtration system is on my D4 2T. Thank you so much,
regards,
Tony
Have tried to create a PDF of the photos if anyone prefers that format?
Just an experiment, not sure if it's downloadable as is or need some modification? Let me know.
Tony, that was brilliant, thankyou very much, so much easier than having to download the sheets one at a time, even out here in the outback with dodgy slow internet, it printed off in a few seconds.
Thankyou
Mike
That PDF conversion is the Cat's meow!! It can be downloaded in an instant and stored on one's desktop or wherever. The ability to change the magnification is a big plus.
Thanks!
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
