Cat 60 crank case oil capacity
3 years 10 months ago #223326
by CLB40hp
How many gallons of oil does it take to change the engine oil in a Cat 60?.
Serial no. 2713A . What oil is best?
Thank you received: 70
3 years 10 months ago #223334
by phildirt
Good Morning:
The crankcase capacity on the Sixty is 20 quarts.
Attached is Form 2032 "Lubricants Recommended for Caterpillar Machines". This sheet was an insert to the 60 Serviceman's Manual.
I run SAE 40, non detergent in mine all year round. Most anything "CBS" (cheap, black and slippery" will be fine.
Thank you received: 37
3 years 10 months ago #223335
by naylorbros
The Thirtys use the same oil pan and both are like Phildirt said very happy with a 5 gallon bucket of oil.
3 years 10 months ago #223340
by CLB40hp
Thank you for the good information. Oil has not been changed in 20yrs so it’s time!
3 years 10 months ago #223341
by phildirt
Only 20 years? Don't need to rush maintenance.
Pull the left rear door (engine side plate) and lift out and clean the oil strainer assembly - you will probably find some strange and wonderful stuff in the bottom.
The parts book and attachments parts book show 3 different sump parts numbers and 4 different "oil gauge" and "elbow" part numbers (your tractor should have left the factory with 2653-A elbow and 2655-A plunger).
When you fill it with 5 gallons of fluid, see where it comes on the dipstick. You may need to make a different mark to show as full.
Send me a PM with your email address and I will send you a specification sheet I have put together on the 60.
Time to create page: 0.156 seconds
