7F-9084 oil pressure gauge on a D4400?
Thank you received: 104
3 years 11 months ago #223113
by Deebo
Dumb question, I know that CAT produced the above gauge to give a more sensitive scale for oil pressure range on the D315, I know there was a service bulletin out about it. So I thought I'd be clever and put one on my D4400 powered 2T. But having read in the Servicemen's Reference Book that the operating pressure for the D4400 should be 30 pounds, I'm now thinking maybe this gauge won't be suitable? Anybody used this gauge on a D4400? And if it's the wrong gauge what should I be looking for instead?
Regards,
Tony
Thank you received: 341
3 years 11 months ago #223116
by edb
Hi Deebo,
Cat literature below on the gauge scale readings---hope this helps.
Cat gauges read maximum pressure reading at the pressure indicated and are so designed to not be damaged at reasonable cold oil excess pressure readings above the maximum indicated.
hfdzl
Thank you received: 153
3 years 11 months ago #223119
by rax200
Hi Deebo,
The updated part for D4 2T oil gauge is 1W5353 the old part no is 8B2355.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 187
3 years 11 months ago #223128
by Mike Meyer
Hi Daryl, do you have a photo of that 1W5353 oil gauge, I'm curious to see what the face looks like.
Mike
Thank you received: 90
3 years 11 months ago #223134
by Deebo
So reading that bulletin from Eddie it says in there about operating pressure being 30psi for those engines too so that makes me think the 7F-9084 will work for the D4400 too. And Handy on startup as it’s more sensitive or am i missing something as usual?
3 years 11 months ago #223137
by Mike Meyer
Thanks for the links BruceOz, the only negative with those new gauges is they are too "modern" looking for my old girls, we need accurate oil pressure gauges but they need to look right too, the subject of making new oil gauges for old Cats has been mooted for a long time.
3 years 10 months ago #223141
by rax200
Mike
Hi Mike,
Here is a photo of the new gauges
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Time to create page: 0.201 seconds
