- Thank you received: 16
Hi MM,
there is likely a S/No plate on the firewall just near where the de-compression lever is or would be if a direct electric start engine.--near the right brake pedal.
Eddie B.[/quote
Yep, there too.
It would be above the starting engine transmission on the diesel engine block. The one on the rear left frame is probably covered by the winch. Looks like a high hp built from "66" to "69" starting with SN 48A6884-up.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
