Engine Id help
Engine Id help
Thank you received: 21
3 years 11 months ago #222717
by Mschwartz
Hello, looked at a hot rodD6 9U. Engine tag was 62U5 power plant. I could not find any info on this site about it. It is a 6 cylinder engine, similar to a D333 or 3306. Turbo and precup glow plug engine. Tractor been setting 20 plus years so I want to figure out what it is before I make an offer on it. Thanks, Mike
3 years 11 months ago - 3 years 11 months ago #222719
62Uxxxx series is a Military D333C engine (4-3/4" bore).
Would be interesting to know what all had to be done to fit the engine installation.
Thank you received: 191
3 years 11 months ago #222721
by D4Jim
Mike, how do you find all these yellow disabled critters in your area??
Good Job.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
3 years 11 months ago #222722
by Mschwartz
Thanks OM. So would that likely be a generator power unit? Any idea on horsepower rating or rpm? Tried searching the internet various ways for D333c military specs but struck out. Safe to think that parts will interchange with other crawler tractor D333C? Thanks again, Mike
3 years 11 months ago #222723
by Mschwartz
Thanks OM. So would that likely be a generator power unit? Any idea on horsepower rating or rpm? Tried searching the internet various ways for D333c military specs but struck out. Safe to think that parts will interchange with other crawler tractor D333C? Thanks again, Mike Looks like they attached a caterpillar oil clutch, hood was cut out for turbo and dry air cleaner. Throttle governor housing is unpainted aluminum so likely that was changed. Drive shaft appears longer than an original 9u. Did not notice any other transplant details.
3 years 11 months ago #222724
by Mschwartz
Most all of the farming was done with crawlers around here before large wheel tractors and rubber belts took over. Scrap iron has claimed a lot of them but a lot of farms still have one or two setting around. Tractors seem to have a way of finding me, ha ha
3 years 11 months ago - 3 years 11 months ago #222727
Ratings are all over the map. Compared to an early 66Dxxxx (D333C) engine the industrial version is rated from 175-250 hp w/o fan at 1500 to 2000 rpm. The Gen set version 135 - 190 hp for the same rpm. Nothing unique about the Military version, parts will interchange.
Thank you received: 620
3 years 11 months ago #222729
by Rome K/G
Thats whats got me wondering about this 561C with D333 with a turbo, it's an 85H series.
3 years 11 months ago #222730
by bluox
A 62U is a D-333C used in a military truck for the army called a GOER I think they were around 215 HP.
Bob
Engine Id help
