R2 cooling system
R2 cooling system
Thank you received: 50
3 years 11 months ago - 3 years 11 months ago #222707
by hfdzl
Good news is the the tractor run well. How ever the gasket between the head and water neck blew out. Engine will come up to temp 185. Very bottom bottom rad pipe stays cold. I didn't make any special gaskets with no hole. Is there a circulation diagram some where?.. Ran for over 30 mins.
Has me puzzled. Prolly take the whole mess apart.
Thanks Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Last edit: 3 years 11 months ago by
hfdzl.
3 years 11 months ago #222710
by hfdzl
Took everything apart. No apparent issues, thermostat works. Unless that rad is so efficient that it cool very well.
3 years 11 months ago #222747
by hfdzl
I believe that I have remedied the situation. Looks as if there is way to much bypass from the top neck as designed. I made 1 of the gaskets with a 3/8 " hole. Not to block off but to slow the circulation down in that pipe.
To be continued
R2 cooling system
Time to create page: 0.125 seconds
