D 2 fuel transfer pump.
Thank you received: 191
3 years 11 months ago #222518
by D4Jim
Here is a pic of a typical transfer pump, maybe it will clarify your question or are you referring to gaskets?
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
3 years 11 months ago #222524
by tomprice
Many thanks for the help. Cover No 19 and Body 21 and Bracket 22 don't seem to have gaskets between them. What seals them? Regards Tom Price
Thank you received: 620
Thank you received: 341
3 years 11 months ago #222544
by wimmera farmer
I believe the reason for no gaskets is to maintaine the very close end clearance on the pumping gears. Any extra clearance will seriously effect pumping performance. If the cover shows wear or score marks it can be relapped to dead flat but if there is wear in other places it may not help much.
tomprice
Thank you received: 31
3 years 11 months ago #222651
by oldbeek
Think the new tolerance is ..002 . I measured mine with plastigauge. Just went through my manuals and cant find it. But .002 is just .001 per side clearance. Don't know why these machines didn't at least have a pre screen.
3 years 11 months ago #222658
by edb
from a No12 Grader Service Manual with the D333 Engine in the Spec. sheet we are given :-
clearance between gears and cover --- 0.001"-0.0022", with a max. of 0.0035"--this is what we applied at the Dealer to all similar designed transfer pumps.
For light worked machines a bit more is likely OK.
tomprice
Time to create page: 0.160 seconds
