- Thank you received: 16
Well I had an excellent conversation today with a great tire supplier that is in the process of making 10.00-24.00 grader tires!
They are expecting the first batch to arrive in November, i would encourage you to call and put your name on a list to reserve you a set if needed.
www.millertire.com/categories/road-grader/
They also have front tire options:
www.millertire.com/categories/antique-tr...tires/front/7-50-20/
www.millertire.com/antique-trucks-cars/a...truck-tires/7-50-20/
Just passing along what i discovered for your information.
What I have found impossible to find is the 9:00 x 24:00 6 ply ribbed front tires for the Cat 112 early '50s. I have looked for years including the Miller website and also had a local tire dealer checking and so far "nada" nothing! Another one is the 18:00 x 24:00 scraper tires used on the LeTourneau units. I am told that 19.5 x 24:00 backhoe tires can be substituted but we have to get rid of the bee nests in the old tire first!
JanM
tried to send a pm,,, ??? Get a hot shot no pest strip at hd or Lowes. $8.00,,, Hang it near the tire and cover the whole tire wit poly. Also if you have bees going in and out of a hole, cut a strip of it that will fit into the hole with still room for them to walk in and out. No pest strip is deadly on bees. Works every time. bees going in and out of a large area? Cover it with black polly. Cut a small hole for bees to come and go. Put pest strip in hole after they start using the hole.What I have found impossible to find is the 9:00 x 24:00 6 ply ribbed front tires for the Cat 112 early '50s. I have looked for years including the Miller website and also had a local tire dealer checking and so far "nada" nothing! Another one is the 18:00 x 24:00 scraper tires used on the LeTourneau units. I am told that 19.5 x 24:00 backhoe tires can be substituted but we have to get rid of the bee nests in the old tire first!
JanM
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
