Cat thirty
Cat thirty
4 years 1 month ago #221171
by Bluegrass1985
Just attempted to start my tractor for the first time. I removed the oil pan and oil pump and cleaned ninety years of gunk out. Also went threw the carb. Installed new rings and did a valve job. Pulled it just a few feet and it started right up. Just ran long enough to see that the oil pressure cold was 18 psi. When I took the Oil pump apart I lost where I wrote the number of turns on the relief. Crank bearings are tight. Does this seem to low? Didn’t run long. Carb leaks like crazy. Do I need to turn Oil pump up? Who sells carb kits for Ensign carbs.
Thanks Don
Thank you received: 341
4 years 1 month ago #221179
by edb
from my grey Thirty Tractor Operators' Instruction Book
For early plain shim adjusted big end bearings for S/No's below S-9268 and PS 9070 = 10 PSI.
For later style shimmed bearings =25 PSI.
Not sure of differences in shims but I would expect that the later shims have Babbitted bearing metal facings facing the crank journal.
Thank you received: 90
4 years 1 month ago #221186
by Bluegrass1985
Thanks for the response. I think that I am going to turn it up a bit. Is there anyone selling Ensign overhaul kits ?
Thank you received: 37
4 years 1 month ago #221190
by naylorbros
Plain shims are not babbitted on the surface that runs against the journal. The later shims have a babbitted surface that runs against the journal.
Cat thirty
