Another run of 20 and 30 manifolds
4 years 1 month ago #221110
by ianoz
Expressions of interest .
Due to a request for these parts .Another batch will be made .
Post up here if anyone needs them .
4 years 1 month ago #221278
by Hotrod392
I’d be potentially interested in an intake for a big Twenty.
Cat Ten
Cat Twenty
Cat Sixty
Cat D4
Cat 66 Grader - hand controls
4 years 1 month ago #221321
by ianoz
Hi Hotrod , Will check to see if inlet manifolds are being done , and will get back to you .
Hotrod392
4 years 1 month ago #221322
by ianoz
We are Re-Running the Cat 20, Cat 25, Cat 28, Cat 30, Cat 35/40 and CaT R5 Manifold Projects Again !! Anyone on ACMOC Forum Interested in joining in ???
Thank you received: 50
4 years 1 month ago #221324
by hfdzl
How about heat valves for 22?
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
4 years 1 month ago #221327
by ianoz
Sorry Herb , unfortunately the 22 is not on the list for parts remanufacture
{Wally } Brewzer seems to be the go to man for second hand 22 parts ,Check what Wally can help you out with .
4 years 1 month ago #221328
by Skidmarc
I’ve just picked up a 1928 L series twenty. Both the intake upstand pipe and intake manifold aswell as the exhaust manifold are a bit worse for wear. Depending on price to to NZ I would be keen. Thanks
4 years 1 month ago #221343
by hfdzl
Just asking, plenty of 22s around.
Thank you received: 409
4 years 1 month ago #221349
Not many with good manifolds unfortunately. I built mine up in a tedious manner using mild rod and gas, just to get a bit of thickness in there and fitted a juicy thick gasket to keep it gas-tight.
Time to create page: 0.170 seconds
