D4 O ring question
D4 O ring question
Thank you received: 187
4 years 1 month ago #220977
by Mike Meyer
Can someone please give me the size of the O ring 2A3314 used in the D4 fuel transfer pump, or a updated part number, I can't find it listed with my local Dealer, also if there is a later part number for the gasket 4B5098 for that pump I'd appreciate it.
Mike
Thank you received: 153
4 years 1 month ago #220978
by rax200
Hi Mike,
Here is the updated numbers,
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
4 years 1 month ago #220989
by Mike Meyer
Morning Daryl, thanks for those numbers, I wonder why my search at Cat Parts Store did not offer any part options at all for both?
So that small one piece gasket on the transfer pump face, has become 2 gaskets and a seal, is that correct?
Mike
4 years 1 month ago #221500
by Mike Meyer
Got the new Cat parts in the mail, unfortunately that new gasket number is not the correct part for my pump, not even close to being right, so I'll need to make one, no biggy, interestingly I must of had the same issue 8 years ago when we worked on that transfer pump, because in my parts box for the D4 I found the exact same new gasket, that obviously I'd bought, and hadn't used.
Edb or Old Magnet, that small gasket 2A3862 (now 6H9949) that sits in under the fuel transfer pump "Seat" 3B4749, is there any reason why I couldn't use a suitable sized O ring there, that would crush to the right thickness, instead of cutting that skinny little paper gasket to fit it in under the seat. I really do not want to risk upsetting the new pump shaft seals pulling the transfer pump shaft out simply to fit that small gasket, if I can possibly avoid it.
Eddie, I know you mentioned having previously cut a gasket like that one at 45 degrees to slip it into place, then glued it closed again, I assume using something like super glue?
Mike
4 years 1 month ago #221528
The o-rings/seals used are not common trade size o-rings. I can furnish dimensions if needed.
The 4B5098 gasket is still a good number, maybe try after market for the one piece version.
Common to see them split to avoid messing with the packing arrangement, just use a dab of aviation gasket cement to reseal the cut joint. I don't think substituting an o-ring is a good idea.
4 years 1 month ago #221542
by Mike Meyer
Thanks Pete, appreciate your thoughts, I'll make a new gasket and create a seam that allows it to slip over, then under the seat, as you suggest. In case anyone is wondering, the "seat" in the photo is a spare I have here.
I was thinking about using a O ring after seeing them in my #41 hydraulic pump, figuring if they can handle that purpose, they should handle a low pressure situation.
Those new shaft seals are very easy to damage, I remember all too well the challenges I faced the last time I repaired this transfer pump, luckily Eddie B stepped in and helped overcome the obstacles, but I'd very much prefer not dismantling it again.
Regards
Mike
4 years 1 month ago #221544
If your faced with having to repack again might consider going to lip seals like later pumps. Modest machine work required.
4 years 1 month ago #221549
by Mike Meyer
Interesting thought Pete, I'd never considered that, or knew that Cat had moved away from those graphite soaked, wedge style seals.
Mike
4 years 1 month ago #221557
Late pump example...
Seal conversion was a service by Bill Walter along with injector testing and refurbishment.
I don't know that anyone in the club has taken up the operation.
4 years 1 month ago #221559
by Mike Meyer
Very interesting, thanks Pete, I see my 3B4749 "Seat" has become a "Cage", and they have done away with the small recessed gasket sitting under it, the 6H9949, looks like a small external O ring 6J2419 now used on the cage for sealing, much more user friendly.
Thanks again
Mike
D4 O ring question
