Need torque spec please
Thank you received: 22
4 years 1 month ago #220877
by TomTrack44
Need torque for mounting side blade carry plates for tool bar dozer for D6 9u, 3/4 in bolts? The appear to be NC and 10tpi, with a taper section just under the head which takes a 1 1/8 sockek. thank you, Tom
Thank you received: 620
4 years 1 month ago #220891
by Rome K/G
Cat didnt have a torque setting for those bolts. I have just used standard grade eight torque specs. Lubed is 282 ft lbs and dry is 339 ft lbs. 250 ft lbs with anti-seize should be good. Recheck them after a few days work.
Thank you received: 251
4 years 1 month ago #220892
by juiceman
I just use a 3/4” drive air wrench...check again after use!
Can’t wait to see it in action Tom.
4 years 1 month ago #220893
by TomTrack44
Thank you, rechecking good adivice. Tom
4 years 1 month ago #220905
by Rome K/G
I have had these tapered bolts break easy with too much torque, they are week at the end of the taper.
Thank you received: 70
4 years 1 month ago #220907
by phildirt
If this is the bolt type that you are referring to, they are the strongest bolt you will find anywhere on a Cat machine. Far stronger than any grade 8 ever made.
I have taken them out after being in place for 60 years using a 1" drive 3:1 torque multiplier using 6 feet of pipe on the 3/4" ratchet. You can break them, but it will take some effort.
Don't worry about over torquing them when you put them it - turn the impact gun up and pound them in.
4 years 1 month ago #220909
I wouldn't got that far, I've managed to break two of those side plate bolts, both in the same place, both sides and yes they sheared where the taper hits the thread and this was during the removal process.
4 years 1 month ago #220927
by phildirt
Read the post ---
I didn't say you couldn't break them. If you ram and slam you can probably break most anything.
