- Thank you received: 153
Thank you very much Daryl. No need to create more work for myself. I will see about tracking those down.Hi Mangnoman,
You are saying you are using Autolite 386, i just looked up the specs on them and they say they have a resistor in them. You may want to change them to non resistive plug as magnetos do not like the resistive type, it will kill your magy eventually.
Try a NGK: AB6 (Stock no. 2910) non resistive
Regards
if you have shelled out the $$'s for a plug that is deemed not compatible with a magneto ignition system then you may like to try this trick.
Your results may vary--worked for me.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
