- Thank you received: 504
I was referring to the starting engine clutch housing ONLY! NOT automatic transmissions!How do automatic transmissions survive when filled with ATF? By Rome’s logic we should be using 30 weight motor oil in all automatic and power shift transmissions. We don’t, we use transmission fluids. The key difference between a transmission fluid and a motor oil is the additive package used in the fluid. Transmission fluid has both extreme pressure lubricants to prevent wear and friction modifiers that make brakes and clutches operate smoothly without slipping.
The Caterpillar pony motor gear train/pinion clutch compartment is NOT an engine crankcase, it’s more of a transmission/wet clutch/brake application. It doesn’t need the additive package of a motor oil and operates properly when filled with a transmission oil. If you don’t like the idea of ATF, use a TO rated fluid instead.
Hi greengiant, did you get some helpful feedback from this thread? As you can see, lubrication is a contentious topic : )
I latch the starter pinion in before starting my pony. If the pinion gear doesn't quite mesh with the flywheel ring gear then all I have to do is rotate the pony flywheel by hand a little bit to get the proper gear meshing. No need to grind it in then if your clutch brake doesn't brake well.
However, it doesn't help if your pinion pops out before the diesel starts. Then you probably are needing it to grind in.
As far as proper lubrication, I think you probably are fine using ATF or the book recommended oil. I get the feeling that as long as there is some lubricant in there that is reasonable to use that it should be fine and probably outlast any other part of the tractor if you didn't use the book recommended oil. I don't think many people have had the starting engine clutch and pinon assembly as something that is a major problem if you use the "wrong" oil in it.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
