Diesel Piston
Diesel Piston
16 years 1 month ago #19055
by redsisbest
My thanks to all who helped me in the past with my D8-15A CCU. When I pulled it down I found the bottom anchor of the brake lining had broken the weld and caused the end to curl inwards, forcing the band away from the drum. Removed the small lining, straightened, and welded. All is good again. Now.......working on a new prototype to use hydrogen with diesel engine to stuff something up the oil companies and rag heads where the sun don't shine. I'm calling to the scrap piles in your memorys where I can find a diesel piston for a 3-1/4" bore. Don't care what it came out of as long as the fore is right. Might be off a Gen-set or something?
Red
Thank you received: 9
16 years 1 month ago #19058
by ccjersey
D3400 engine used in D2 J series, 212 grader before 1948, gen sets etc.
I don't have one, but someone will.
16 years 1 month ago #19059
by SJ
CC the D2 your talking about has a 3 3/4" piston in them as he stated he needs a 3 1/4"
16 years 1 month ago #19089
by ccjersey
Didn't read the fine print!
Diesel Piston
