d47u greasing
d47u greasing
4 years 2 months ago #219939
by rouger
looking for help for greasing track rollers and drives if anyone has detailed pic of the locations. also looking for oil filter and recommendations on this . machine is new to me 1959 d47u
Thank you received: 191
4 years 2 months ago #219941
by D4Jim
It would be a good idea to pick up an operators manual and parts book for your machine from someone on this board or on eBay. There are usually some good used manuals and I would recommend you stay away from some of the high priced poorly copied reproductions on eBay. Your track rollers are either the button grease type or the oil filled ones that take different grease / oil.
On these old machines often the parts on the machine have been updated and or replaced and are not the original type, particularly on track rollers. If you get a chance send us a picture of the "new" toy.
ACMOC Member 25 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Thank you received: 620
4 years 2 months ago #219942
by Rome K/G
Welcome, your tractor should be equipped with lifetime oil filled rollers that do not need serviced until rebuild. Engine oil filter from Cat will be a 1R0659.
Thank you received: 142
4 years 2 months ago #219943
by bursitis
i use a regular lever grease gun and corn head grease in my bottom rollers. i just got a buttonhead fitting and put it on a hose. caution when filling the rollers is to pump slow and when you feel a little back pressure you need to stop so you don't blow the seals.
Thank you received: 90
d47u greasing
Time to create page: 0.138 seconds
