- Thank you received: 0
Are you removing the tandem axle or how much are you removing and replacing? I am not the expert but I have never seen a service manual for the tandem drive, only a short supplemental manual for the transmission.
Hello,
I am only tearing down to the tandem bearing behind the sprocket. The axle, bearings, and seals, appear to be good on the final drive assembly. I wasn't going to tear down further unless the axle ended up being out of true.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
