- Thank you received: 5
Hi George,
great to hear that the engine is settling in with more run time.
The warm up time should be covered in your Grey OMI--from memory, run engine at half RPM for around 5 mins. also the book would say another 5 at full RPM until the engine and transmission, etc. is warmed up. I usually am easier on equipment than this and 3/4 speed should suffice.
As you suggest times can vary according to the ambient temperatures--wind chill, etc. and I did not pickup on a rant--you merely stated the facts about your particular machines past that after much hard work and cost you now have operating well and improving with run time also it seemingly is now exceeding your expectations.
The hallmark of a good operator is how smooth he can operate his machine with no sudden impacts and such, all done with the least number of RPM's for the task at hand.
Recently Misterskill put up a video of ripping his opal mine site, doing the job easily and gently at less than full RPM and available power--this is economic on fuel and longevity of the machinery--any cowboy can rip tear and bust with lots of noise, smoke, and speed and achieve little more than a good steady operator but certainly ruin a good quality machine that costs mega to fix with parts that are now getting harder to find.
In fact the mine sites here used to rack back their D9's etc. to try and prevent/slow down the cowboys wrecking them.
If ever you get to operate a drag-line equipped excavator you will soon come to realize that smoothness is the order of the day for best performance that shows.
One thing that a person could do regarding drawing in colder but moist air after shutdown is to fit aero-style dessicators. They look like a test tube filled with purple crystals and trap the moisture.
i get what you're talking about Neil...dessicate...remove/absorb water...never seen them tho...
Hydraulic hose made to fit or buy a new section of steel line and braze the ends on it.
First thing I would try is brazing the hole/crack in the old one. Properly done it should make a permanent repair.
P.O. Box 9301
Peoria, IL 61612
(309) 691-5002
cat@acmoc.org
- Chris R
- Jason N
